Technical Forum
Virtual Server between two subnets belonging to two different Traffic Groups.
Albert_Coll
Cirrus
Cirrus
I should create a Virtual Server in a BIG-IP LTM DSC active-active group between two vlans assigned to two different Traffic-Groups.
The BIG-IP LTM allows to setup a Virtual Server by setting as Source and Destination Addresses the Floating IPs of both vlans belonging to different Traffic-Groups respectively. I understand that this shouldn’t pose any problem if both Traffic Groups are active within the same BIG-IP LTM member of an active-active DSC
My question is what will happen if one of the two Traffic-Groups fails over to another member of the active-active DSC?
1 REPLY 1
You have Traffic Grp1 active on F5-1 and Traffic Grp2 is active on F5-2. Now you are asking if any one of the Traffic Group fails over to the other unit for any reason, then what will happen?
In this situation, both traffic groups should be handle by single unit if failover part is configured properly.
