Viprion HA failover configuration
Sajan_Mania_381
Altostratus
Altostratus
If we configure 2 f5 ltm in 2 different blades of same Viprion box do we need a physical connection between ltm1 and ltm2 for establish a trust relationship or for Network Failover ?
2 REPLIES 2
I think it's got two vCMPs on each blade, right?
If that is the case, you do not need a physical connection to establish network failover and trust, they communicate within the chassis, however, this type of architecture is not a good practice.
Samir_Jha_52506
Noctilucent
Noctilucent
No physical connection required if two LTM in two blade but in 1-Viprion chesis(only for failover).
However you need to establish HA trust for failover. In production environment we never prefar this module.
