Technical Forum
VIP with URL domain changeable?
shadow82
Altostratus
Altostratus
Hi!
I have recently built HTTPS VIP in domain (for example) https://vip.contoso.com and got a request to prepare to switch it to domain https://vip.acme.com
Which profile setting should I look for to build vip: https://vip and attach... "domain profile(?)" to use it in this or that domain?
I'm aware that 2 SSL Client profiles with dedicated certs will be necessary, just asking about domain part in URL to make it switchable.
Question regards F5 Big-IP VE 16.1.3
1 ACCEPTED SOLUTION
mihaic
MVP
MVP
your VIP is HTTPS and has an IP. A DNS entry is pointing to your VIP IP. You will need of course a new DNS entry(new domain) for the vip.
If you want this VIP to serve a different domain you need a new SSL profile for the new domain.
Also if you have irules specific for the old domain you might need to change them also or have new irules for the vip. This is case you have irules that match the domain name
2 REPLIES 2
mihaic
MVP
MVP
@shadow82 - I'm going to mark @mihaic's response as the accepted solution. If it didn't work for you, please let me know and I'll revoke that change.
