Sort By
Personally, I use kali linux for various app traffic generation. Depending on what you need, you could also just use a variety of curl scripts for the http. Also, for less hack-ish mechanisms, check out the tsung project. It's node-based. You can generate from many nodes.
- T-TrustCirrostratus
Hi So i think you can deploy centos, ubuntu, kali or redhat and install hping 3 to generate traffic, I hope this information will help you
