Kannan_Thalaia1
Jun 12, 2020Cirrus
vCMP Migration Issue
Currently we are migrating our physical devices ( in two datacenter) into virtual one (vCMP Guests).
The both DCs are using same VLAN IDs but using different IPs.
For example same VLAN ID 503 but the IP address used in on DC is is 10.10.188.* and another DC 10.20.125.*
As we learned that "The vlans are handled at the Host level.The Host administrator will create them and then they can be used per guest. Since the host is the same for all the guest, the vlan ID has to be unique."
How we can merge these DCs LTM (as vCMP guest) into single Chassis (vCMP Host)?
Any help is highly appreciated.
Regards,
Kannan.
