neeeewbie's avatar
Feb 24, 2021
Solved
vcmp guest cpu devide to control and data plane?
Hi guys
I need your help!!
does vcmp guest cpu auto divide to control and data plane?
Is control and data plane have two cpu allocated if we allocated four cpu to guest??
thank you
  • Yes, exactly.
    https://www.devcentral.f5.com/s/feed/0D51T00006i7iYmSAI
    BTW, take into account this as well.
    https://support.f5.com/csp/article/K16585
    Regards,
    Dario.
  • Hello Neeeewbie
    I recommend you to check these articles
    https://support.f5.com/csp/article/K15003
    https://support.f5.com/csp/article/K23505424
    Regards,
    Dario.
    • neeeewbie's avatar
      neeeewbie
      Icon for MVP rankMVP
      Hi
      thank you for shared information
      if we allocated one CPU to guest, how to operating CPU?
      cpu do auto divided data plane and control plane ?
      • Dario_Garrido's avatar
        Dario_Garrido
        Icon for Noctilucent rankNoctilucent
        Yes, exactly.
        Regards,
        Dario.
