Sort By
That is expected behavior when upgrading to 13.1.0. Simply modify the SNMP monitoring to ignore this file system.
K22410024: New read-only file system for APM Clients reports 100 percent disk utilization
I upgraded a F5 Cluster and since then i see a new mount for /var/apm/mount/apmclients-7160.2018.118.2335-4172.iso which shows 100%. Due to this, our monitoring device is marking it critical.
What is this used for. Also, can we umount it.
Regards Sheetal
