will_lee_113506's avatar
will_lee_113506
Mar 29, 2005
V9 configuration related question
This isn't exactly a v9 iRules question, but I'm not aware of a v9 system configuration forum in general...
we've got two BIGIP 3400 units running in an active/standby configuration. Both units are connected and Config Sync'ed. We entered all the VIP, iRules, profile, node information into the 1 active unit. After which we've performed a ConfigSync and synchronized to the peer. Both systems say they are sync and OK. But all the iRules, profiles, VIP information is not showing up on the 2 standby server.
Does ConfigSync not synchronize the iRules, VIP, node information?
-Will
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    No, ConfigSync is supposed to synchronize iRules, VIP and node information. You will need to contact support so they can help diagnose what happened.
    Thanks.
