Geoff_Littlewoo
Jul 24, 2009Nimbostratus
Use iRulke to extract X-Forwarded out of HTTP packet
I have a polling HTTP pakcet that the LTM does not see as a proper compliant HTTP packet.
Due to this the device sends a single packet in and the F5 closes the connection. This connection needs to remain open. To fix this, the HTTP profile is removed from the Virtual Server. The X-Forwarded header is needed fromn the packets that then flow through the LTM. The X-Forwarded header becomes the IP address of the LTM and not the source device.
I am looking for an iRule that will look at this packet and extract the X-Forwarded contents and send it through, as the souce address sent becomes the interface of the LTM.
