DaleLeBlanc_140's avatar
DaleLeBlanc_140
Mar 29, 2016
URI transformation
I would like to have iRule select a pool and transform the URI similar to shown below:
Client enters:
    https://www.test.com/alpha
For communication between LTM and server, I need the URI to be transformed several directories down:
    https://nodeip/random/deep/level/directory/structure
So, final result is the client only sees https://www.test.com/alpha, but the entire URI /random/deep/level/directory/structure is sent to the node.
  • Hello,
    You can use an irule to translate the client URI to the server using the following command : HTTP::uri
    You can also use an LTM policy to do the job
  • Hello,
  • Hi Dale,
    Make sure you apply Stream profile on VIP before applying below iRule.
            HTTP::header remove Accept-Encoding
            STREAM::disable
            when HTTP_RESPONSE {
             Disable the stream filter for server responses
            STREAM::disable
             Enable the stream filter for text responses only
            if {[HTTP::header value Content-Type] contains "text"}{
            Replace 'old_text' with 'new_text'
           STREAM::expression {@https://nodeip/random/deep/level/directory/structure@https://www.test.com/alpha@}
             Enable the stream filter for this response only
            STREAM::enable
    For reference please visit this link
