tfs128's avatar
tfs128
Jun 09, 2020
URI rewrite with wildcard
Working on setting up an irule and have been using this post for reference.
Request will be coming in as https://site.domain.com/text1/text2/text3/wildcard/text4, where the wildcard can be any app name and the other values are constant.
Then we need to rewrite the uri to be /text5/text6/text7/wildcard/text4. We'll be keeping the "/wildcard/text4" part of the uri but the rest will be changing. So the request will look like https://site.domain.com/text5/text6/text7/wildcard/text4
Then send it to a different pool.
Have come up the following, though the skip_count was confusing me a bit. I assume I don't want any characters to be skipped when pulling in the wildcard value. I saw that regex is discouraged due to cpu, so not sure if there's a better way to accomplish this.
  if { [string tolower [HTTP::uri]] matches_regex "(\/text1\/text2\/text3).*(\/text4)" } {
    set filter [findstr [string tolower [HTTP::uri]] "/text1/text2/text3/" 0 "/text4"]
    set newuri [string map "/text5/text6/text7/$filter/text4" [string tolower [HTTP::uri]]]
    HTTP::uri $newuri
    pool pool1
Thanks for any assistance.
  • Hello,
    Is that URI a fixed one with one wildcard piece?
    If so, I would do this way:
        # Checks whether the path starts with /text1/text2/text3 and ends with /text4
        if {  [string match -nocase {/text1/text2/text3/*/text4} [HTTP::path]] } {
            # Put /text5/text6/text7, append original URI from 18 char to end (Skip the starts length from /text1/text2/text3)
            HTTP::uri "/text5/text6/text7[string range [HTTP::uri] 18 end]"
            pool pool1
    Regards
    • tfs128's avatar
      tfs128
      Correct, only the wildcard can vary. It will always come in starting with /text1/text2/text3 which I'll need to change into /text5/text6/text7. The /wildcard/text4 will always end the URI.
