Upgrade from 13.1.3.6 to 15.1.2
joyride_us
Altostratus
Altostratus
Hi guys!
I am planning this upgrade. Anything specific to plan ?
Please think twice since last time (from 13.1.3.3 to 13.1.3.6), there was big bug with no import of the BigIP config since the cipher was not approved by 13.1.3.6)
thank you for your help
2 REPLIES 2
Sounds like a good plan. This is a supported upgrade path: https://support.f5.com/csp/article/K13845
Cheers,
Kees
crodriguez
F5 Employee
F5 Employee
...and, if you need guidance with the upgrade/update, you can also look at the (relatively) new BIG-IP Update and Upgrade Guide on AskF5.
