Dennis_Kloosterman's avatar
Apr 12, 2018
Unexpected failover, ipsec_ha_unit_mask_changed
I have tried troubleshooting an unexpected failover between two BigIP's using F5's troubleshooting guide, but was unable to find anything relevant.
I did find a line in the tmm log of both devices that scores 0 results on Google:
Formerly active device:
<13> Apr  7 01:19:54 [device name removed] notice ipsec_ha_unit_mask_changed/159: PFKDB: Box is ACTIVE now!
Formerly standby device:
<13> Apr  7 01:20:06 [device name removed] notice ipsec_ha_unit_mask_changed/174: PFKDB: Box becames STANDBY
"becames" is not a type, it's copied from the log.
Does anyone have an idea what this means?
  • Can you goto your log and grep the below,
    zcat /var/log/ltm* | grep "action is"
  • Hello,
    First of you have to determine what's happened for this follow recomendation of this KB:
    https://support.f5.com/csp/article/K95002127
    In this kb it advise you to check LTM logs (just be carreful when failover it's happendm maybe you can't see this event in ltm logs and you have to check in old archive with zcat):
    egrep -i 'failover|failsafe' /var/log/ltm
    zcat /var/log/ltm* | grep 'failover|failsafe'
    Then very important check if you have a core file generated around failover time (Apr 7 01:19:54) in /var/core/ directory.
    https://support.f5.com/csp/article/K10062
    Last point generate a qkview in order to load it in ihealth:
    https://ihealth.f5.com/
    BIG-IP iHealth is the qkview file technology, which provides a running snapshot of your BIG-IP system with up-to-the-minute configuration and diagnostic information. You can quickly download a qkview file from your BIG-IP system, and then upload the file to the BIG-IP iHealth system.
    The BIG-IP iHealth system translates the output from your qkview file and displays the content in a customer-friendly format that mimics the familiar BIG-IP Configuration utility. In addition to translating the raw data, the BIG-IP iHealth Diagnostics component of the BIG-IP iHealth system evaluates the logs, command output, and configuration of your BIG-IP system against a database of known issues, common mistakes, and published F5 best practices.
    Regards
    • Dennis_Kloosterman's avatar
      Dennis_Kloosterman
      Hi Ford,
      I haven't, but we upgraded to 12.1.5.1 a few months ago and I haven't seen this behaviour since.
