John_Barney_102
Apr 18, 2005UDP::payload replace
Anyone know if "replace" is supported in UDP::payload?
The documentation does not list it.
If not, does anyone know of a way to manipulate some data (generically) in UDP packets?
- unRuleY_95363Historic F5 AccountYes, UDP::payload supports "replace", same format as for TCP::payload.
- John_Barney_102
Thanks!
What is the argument list?
For TCP it is TCP::payload replace
If I use that with UDP, I get a "wrong of args" error. Stripping out and/or also returns the same error. - drteeth_127330Historic F5 AccountThe arguments are the same as for TCP. When do you get the error? What version are you running? The following command works fine for me:
bigpipe rule udp_rule '{ when CLIENT_DATA { UDP::payload replace 0 4 "test" } }' - John_Barney_102
We're running 9.0.4.
Error appears when saving the rule through the GUI.
Here's the code:when CLIENT_DATA { set payload [UDP::payload [UDP::payload length]] set blank ā\nā Find the data to replace regsub -all "Replace me\n" $payload $blank new_response Replace the content if there was a match if {$new_response != 0} { UDP::payload replace 0 [UDP::payload length] $new_response } }
Result is wrong of arguments, line 10. - drteeth_127330Historic F5 AccountThe above rule seems to be accepted on 9.0.5. However, I don't recall any fixes for UDP::payload. Check your rule for any trailing or otherwise unexpected whitespace.
- John_Barney_102
Upgrading to 9.0.5 solved the problem!
Thanks!
