04-Oct-2023 04:23
Dears,
I’m trying to import a UCS file obtained from the existing device (i2800 v12.1.5.2) into the VE version V12.1.5.2, but it’s not going smoothly.
The command I execute during import is:
load sys ucs [i2800 UCS File] no-license platform-migrate
Upon checking the log (/var/log/ltm), I found the following errors:
[Errors]
I only need to verify the configurations from the old model; it’s acceptable if maxcore decreases. My goal is to successfully complete the load sys command. Any support on how to address these errors would be greatly helpful.
04-Oct-2023 06:01
@igssv It looks like you did not migrate the master key from the old F5 to the new F5. This can be done easily if you have access to both devices. The following document has the steps which can be found if you search for "f5mku -K" when the page loads.
04-Oct-2023 12:46
Thank you for your quick response! Since the old F5 is still in operation and we want to avoid elevating security risks for our clients, we would prefer not to migrate the master key. Is there a way to review the configurations without migrating the master key?
04-Oct-2023 13:23
@igssv Migrating the master key will not cause any disruption on your existing F5. All you are doing for this is you are retreiving the master key value from the old F5s and then taking that key and configuring it on the new F5s. After that you should be able to import the configuration on the new F5s.
04-Oct-2023 23:06
Thank you once again for your prompt response. So, retrieving the master key itself won't have any impact on the operations. I'll discuss with our client about obtaining it. Thank you.
05-Oct-2023 02:23
I successfully loaded the UCS. Thank you! However, now I'm unable to log in because the passwords for the root and admin accounts are unknown.
I have been referring to the URL https://my.f5.com/manage/s/article/K73551536. However, after booting in Single User Mode and running the mount -a command, nothing is mounted, and I can't use the passwd command.
Ideally, I’d like to reset the passwords and log in. Alternatively, I'm wondering if there is a way to load sys without importing the user account information.
Could you please help with the above? Thank you!
05-Oct-2023 05:38
@igssv The usernames and passwords should be the same as the old F5 device because everything is imported from the UCS into the new F5.
07-Oct-2023 19:24
Hi, Paulius,
As expected, then. Without asking our client, we won't know the account information for the old F5 device. We were hoping to find an approach that wouldn't inconvenience them, like a method of not importing user information. If it's difficult, I'll consider consulting with the client. Thank you so much for all of your responses!
07-Oct-2023 20:08
@igssv If you have access to the old F5s you can change the admin and root password, then create a UCS, and finally import that new UCS which should have the new usernames and passwords. Sadly, sometimes in order to get the job done correct you will have to ask for additional information. It's better to inconvenience them a small amount now then a large amount in the future.
07-Oct-2023 20:49
Thank you for the advice! Unfortunately, it’s already Saturday here in Japan, so I resolved the issue by customizing the UCS as follow.
On the Virtual Edition (VE), the following steps were executed:
- Ran `f5mku -r <old master key>`
- Executed `tmsh save sys conf` to save the system configuration
- Obtained the UCS
In old UCS:
- Added `fallback true` to the `auth source` section in `bigip.conf` (which was initially set to `type radius`)
- Copied the `encrypted-password` for `auth user admin/root` from the UCS on the VE over to `bigip_user.conf`
- Changed `sys httpd` in `bigip_base.conf` to `ALL`
Thank you so much for your consistent guidance! With your help, I've successfully reached a point where I can review the client’s configurations without any issues!
05-Oct-2023 08:07
Hi igssv,
Please collect master key from existing device first
1. on Existing Device
- Go to bash shell > run command "f5mku -K"
- Collect output
2. on New device
- Go to bash shell > run command "f5mku -r <past output>
- Save configuration "tmsh save sys config"
- Load sys ucs again
07-Oct-2023 19:31
Hi, T-Trust
I see, I should save sys config first. I tried it, and during the load, I received a message saying:
Post-processing...
usermod: no changes
I thought it worked well, but it turns out the password has changed. Thank you for your advice!
07-Oct-2023 20:52
Hi, T-Trust,
I would also like to extend my gratitude to you! As written in my response to Paulius, I was able to accomplish what I needed by tweaking the contents of the UCS! Thank you!
08-Oct-2023 22:54
Hi igssv,
You need to do this for platform migration , glad you are successful, you can refer this process for furure migrations:
modify sys crypto master-key prompt-for-password
https://my.f5.com/manage/s/article/K82540512
15-Oct-2023 19:09
Hi F5_Design_Engineer,
Thank you so much for the comprehensive explanation regarding the ”platform_migrate" option! Your insights were super helpful. For this particular instance, our primary goal was simply to deploy the current device UCS to the Virtual Edition and validate the settings, so it looks like we can afford to overlook any potential issues. I might reach out again for advice if we run into any hurdles down the road—hope that’s okay!
Thanks again and have a great day!
