24-Aug-2021 01:35
I am provisioning an i5800 I have set up the vCMP guest and two hosts. I am trying to provision the AFM firewall on one of the hosts but I get this error "The provision module afm requires TurboFlex profile turboflex-security." It seems as if the i5800 should have TurboFlex but there is no tab for it in the provisioning. So my questions are can I provison the AFM with out the TurboFlex and why am I not seeing any TurboFlex CLI comands or GUI options ?
27-Aug-2021
07:10
- last edited on
24-Mar-2022
01:23
by
li-migration
Hi
This is not configured at the level of the vCMP host, but at the level of the guest. This is how it worked in my i5800 vCMP Guest.
Go to System ›› Resource Provisioning : TurboFlex and enable "turboflex-security-v1".
Next go to System ›› Resource Provisioning : Module Allocation and enable "Advanced Firewall (AFM)"
Beware there is a bug in 15.1.3 and 16.x:
But you can still change it via TMSH
https://techdocs.f5.com/en-us/hw-platforms/f5-platforms--turboflex-profiles/1.html
KR
Daniel
30-Aug-2021 00:10
Hi Daniel Thanks for my problem was the options only appears after the initial setup has been completed, you can not configure it from the setup wizard.
30-Aug-2021 03:47
For the sake of completeness. You can have multiple guests and you can assign different Turboflex profiles to each guest.
