02-Feb-2021 10:42
Here is the snippet of code that is used to create the VIPs on the f5;
rv0=revisedServer.replace("dev_","test_vip_")
print (eachServer[0][3].upper())
rv1=eachServer[0][3].upper()
params = {'name': rv0, 'source': "0.0.0.0/0", 'description': "TEST VS",'protocol': rv1,'pool': revisedServer,'profiles': profiles,'partition': 'Common','sourceAddressTranslation': {'type': 'snat'},'vlansEnabled': 'True','vlans': ['/Common/Dev'],'arp':'disabled','icmpecho':'disabled','state':'disabled','port':eachServer[0][1],'tagMode':'none'}
print (params)
#LETS CREATE VIRTIUAL SERVERS IF THE SERVER ALREADY EXISTS KEEP IT MOVING
try:
ltm.virtuals.virtual.create(**params)
except Exception as e:
print (e)
When run I get the following error:
400 Unexpected Error: Bad Request for uri: https://pltbigip01.pexdev.corp:443/mgmt/tm/ltm/virtual/
Text: '{"code":400,"message":"Instance contains a string","errorStack":[],"apiError":1}'
Does anyone know why?
16-Feb-2021 02:44
your 'vlansEnabled' receives a boolean as value. Booleans aren't strings.
So instead of:
Try:
'vlansEnabled': True,
There maybe other errors, so use this as a reference to make sure the values match the expected type:
params = {'name': vs_name,
'destination': '{}:{}'.format('192.168.100.10', str(80)),
'mask': '255.255.255.255',
'description': 'Created by Python',
'pool': my_pool,
'sourceAddressTranslation': {'type': 'automap'},
'vlans': ['/Common/internal']
Cheers.
Rodrigo
26-Apr-2021 17:10
See this question for continuing conversation. Closing this question as dupe.
