Technical Forum
Traffic segregation based on Geo IP Location
rmoss25
Altostratus
Altostratus
Is it possible to seperate traffic based on Geo IP Location?  So for direct traffic from US IP's to one servers and others to another server?  I feel like this could be done using an iRule.
2 REPLIES 2
Ismael_Goncalves
F5 Employee
F5 Employee
You can use an iRule or LTM local traffic policy for it. The following articles can give you an idea.
https://support.f5.com/csp/article/K15097
https://support.f5.com/csp/article/K02479505
T-Trust
Cirrus
Cirrus
Hi Rmoss,
So i think you can use and reference from my result test before about IP geo location,
- How to update geo database
https://cloud-ttrust.com/f5-how-to-install-and-update-ip-geolocation-database/
- iRules check client IP
https://cloud-ttrust.com/f5-irules-check-http-x-forward-for-and-country/
set client_ip [IP::client_addr]
set fromCountry [whereis $client_ip country]
if { ( [class match $fromCountry equals US]) }{
pool pool1
} elseif { ( [class match $fromCountry equals UK]) }{
pool pool2
