j_hardin80's avatar
j_hardin80
Oct 03, 2023
TLS1
Forgive me but I'm pretty green when it comes to these F5's. We have an F5 LTM that is load balancing our internal and external email. We just had a pen test done and they saw TLS1 and 1.1 open from the external IPs.
Pretty simple setup, external email hits our mail URL, it gets NAT'd to internal IP of the F5 virtual server then that goes to our pools. Virtual server is using client ssl profile and I'm assuming that is where this TLS is showing up.
What I need to know is how to find (cli command as we have many virtual servers) what virtual servers are using this specific SSL Profile so I can make sure the external is the only one before I make any changes to the profile.
The current SSL profile option is set with just No_TLSv1.3, wouldn't that mean it's using everything else BUT 1.3? I would want to put v1 and v1.1 in there instead right?
Thanks for the help!
  • HI,
    Not sure it makes much difference but is this HTTPS or SMTP traffic? (only interested for possible context later)
    now, what you want to look at is your client ssl profile.
    Inside there is selection's for "no tls" or "no tls1.1" etc etc. So by selecting the ones you don't want it will turn them off.
    The way i did it, was to use a cypher profile, and link that to your ssl profile. This meant i could have granual control not just of the encyrption used (TLS) but also the hashes which also came up on a pen test for me!
    Have a look if that answers your question, if not let me know and i can send you some links or screen shots.
    • j_hardin80's avatar
      j_hardin80
      Sorry, yes this is HTTPS traffic.
      I'm not so sure we are worried about granularity at this point, so you are saying I should remove the "NO_TLSv1.3" and add the NO_TLSv1 and NO_TLSv1.1 in the options on the client ssl profile?
      But how can find out if there are any other virtual servers using that same clent ssl profile before I make any changes?
      Thank you!
      • PSFletchTheTek's avatar
        PSFletchTheTek
        Ok lets start from a test. If you can find a device that runs nmap that can get to the external interface try running this,
        nmap --script ssl-enum-ciphers -p 443 <Your domain name here.com>
        This should show you what you are dealing with and a method to prove that its worked!
        Then under your ssl profile you need to chnage the config from "Basic" to "Advanced"
        Then you'll see the Options List
        Here is mine, it appears its flow down so NO DTLSv1.2 turns off everything below that and leaves TLSv1.3.
        I don't know a location to see where a profile is used in a virtual server, but if you get a ucs file or the internal conf files out using the cli you could do a quick word search in the config maybe?
        But you can go into the certificates and see which profiles they are used in which might get you "close" to the same place.
        Does that help any more?
  • j_hardin80 If you are in tmsh you should be able to run the following command to find them relatively quick.
    list ltm virtual | grep -E "virtual |<ssl_client_profile_name>"
    This will give you multiple lines but the ones you're interested in are the ones with the virtual server name immediately followed by the ssl client profile name that you're interested in. In the command above make sure to replace the entire string "<ssl_client_profile_name>" with the ssl client profile name in question.
      j_hardin80
      Thank you but I'm not sure it's working for me. No matter what SSL Profile name I use, it gives me the same listing of virtual servers that I know aren't using that profile.
      • Paulius's avatar
        Paulius
        Icon for MVP rankMVP
        j_hardin80 That is correct, it will output all virtual servers followed by the SSL profile. It would look something like this.
        ltm virtual VS_1.1.1.1_443
        ltm virtual VS_2.2.2.2_443
            CLIENTSSL-myprofile
        ltm virtual VS_3.3.3.3_443
        Notice how you have 2 VS back to back and then an indented SSL profile name. You will have to go through the text that shows up in the terminal and grab all VS names that are immediately followed by the SSL profile you are looking for. I don't know of a better way of searching this without doing some complicated regex search.
