Ntinos's avatar
Ntinos
Sep 10, 2020
TLS 1.3 and BIG-IP Virtual Edition - BEST
Has there been any changes in the way TLS 1.3 is configured in AWS BEST AMIs after 15.0.1.1 0.0.3 build. Same config works fine with no error on F5 BIG-IP Virtual Edition - BEST 15.0.1.1 0.0.3 and F5 BIG-IP Virtual Edition - GOOD 15.1.0.4 0.0.6 but not for F5 BIG-IP Virtual Edition - BEST 15.1.0.4 0.0.6.
I'm getting the below error:
curl -v -k https://20.0.5.25/30KB.htm
*  Trying 20.0.5.25...
* TCP_NODELAY set
* Connected to 20.0.5.25 (20.0.5.25) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*  CAfile: /etc/ssl/certs/ca-certificates.crt
 CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS Unknown, Certificate Status (22):
* TLSv1.3 (IN), TLS handshake, Unknown (8):
* TLSv1.3 (OUT), TLS alert, Server hello (2):
* error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac
* stopped the pause stream!
* Closing connection 0
curl: (35) error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac
  • Can you try openssl s_client?
    openssl s_client -tls1_3 -connect 20.0.5.25:443
  • Ntinos's avatar
    Ntinos
    Here you are:
    #openssl s_client -tls1_3 -connect 20.0.5.25:443
    CONNECTED(00000005)
    depth=0 C = US, ST = CA, O = Ntinos, CN = ANG
    verify error:num=18:self signed certificate
    verify return:1
    verify error:num=26:unsupported certificate purpose
    verify return:1
    verify error:num=10:certificate has expired
    notAfter=Jan 30 23:58:24 2020 GMT
    verify return:1
    verify return:1
    139621769810368:error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac:../ssl/record/ssl3_record.c:677:
    Certificate chain
     0 s:C = US, ST = CA, O = Ntinos, CN = ANG
      i:C = US, ST = CA, O = Ntinos, CN = ANG
    Server certificate
    -----BEGIN CERTIFICATE-----
    -----END CERTIFICATE-----
    subject=C = US, ST = CA, O = Ntinos, CN = ANG
    issuer=C = US, ST = CA, O = Ntinos, CN = ANG
    No client certificate CA names sent
    Server Temp Key: X25519, 253 bits
    SSL handshake has read 1463 bytes and written 240 bytes
    Verification error: certificate has expired
    New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
    Server public key is 2048 bit
    Secure Renegotiation IS NOT supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    Early data was not sent
    Verify return code: 10 (certificate has expired)
  • Hi Ntinos,
    Your openssl test reveals that your certificate has expired (Verify return code: 10 (certificate has expired), renews the certificate and this should make it work better😉
  • Ntinos's avatar
    Ntinos
    Why does this happen only on TLS 1.3 and 1.5.1 BEST? TLS 1.2 works fine.
    • Lidev's avatar
      Lidev
      Have you try the same test (openssl s_clien)t but with tls1.2 to see if the result is the same (certificate expired)?
      openssl s_client -tls1_2 -connect 20.0.5.25:443
      • Ntinos's avatar
        Ntinos
        Yes, ceritificate is expired but everything works, curl/spirent etc.
  • DMan's avatar
    DMan
     Were you able to get to the root cause of this issue and able to resolve? I am having the same issue with one of the 15.1.2.1 version.
    • Ntinos's avatar
      Ntinos
      Not really, I had to use the older version...
