08-Sep-2023 02:03
Hi and as per the subject line, is it possible to migrate an AWS F5 instance to an on prem VMWare environment temporailry and then send it back to AWS?
11-Sep-2023 00:52
Hi @xyznetworks,
If your license model in AWS is Byol you can revoke your license in AWS and relicense a new device in your local Vmware and then repeat the process when you want to move your device to AWS.
https://my.f5.com/manage/s/article/K41458656
Hope it´s work.
If your license model is a subscription unfortunately you have to deploy your system in Vmware with a temporal license, you can request it to your SE in F5, or your local partner, just for 45 days.
