Technical Forum
Tcpdump with f5-- ssl flag
Hamza
Cirrus
Cirrus
hello,
i am not able to cupture trafic with tcpdump --f5 ssl :
[root@BIGIP1:Peer Time Out of Sync:Changes Pending] config # tmsh modify sys db tcpdump.sslprovider value enable
[root@BIGIP1:Peer Time Out of Sync:Changes Pending] config # tmsh modify sys db log.ssl.level value Debug
[root@BIGIP1:Peer Time Out of Sync:Changes Pending] config # tcpdump -s0 -ni 0.0:nnnp -w /var/tmp/"$HOSTNAME"_working_"$(date +%d-%m-%y)".pcap --f5 ssl -vv host 105.65.6.7
tcpdump: WARNING:  The "ssl" option is disabled. The "ssl" option cannot be used in Common Criteria mode. Common Criteria mode is controlled by the DB variable security.commoncriteria.
have you any idea please?
1 REPLY 1
Hi Hamza,
If "sys db security.commoncriteria" value is true, you will get this warning.
tmsh list sys db security.commoncriteria
You need to change the value to false. The change will require reboot.
