rs's avatar
rs
Oct 15, 2020
tcp echo
Hi Team ,
I am not sure how tcp echo works , I believe it try to set up the session on port 7 for a destination , I noticed that tcp echo is address check monitor I believe we can assign the same either with node default monitor or use as node member specific
As following below article I have created virtual server listening on port 7 and then created a custom tcp echo monitor with alias address 7 and transparent option selected yes , however noticed that for that node monitoring was failing .
In monitor f5 use self IP as a source , However in that case what would be the source Self Ip as VIp and self Ip are in same subnet .
I tried to run tcpdump via using node Ip and Virtual address did not get nothing .
So please let me know how TCP echo works , is precondition that node/server listen on port 7 and what would be the source ip if we create a custom tcp monitor for virtual server or any internet based destination ?
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-monitors-reference-12-0-0/2.html
