Technical Forum
Custom Alert Banner
TCL error with an universal irule
Jumbo
Altostratus
Altostratus
I implement a VS that use an Irule to do persistence based on XFF information, but I got a TCL error when the server response to the client
It seems it happened only when the client is an Microfocus access gateway , and not if the client is an nginx server,
Irule definition :
  set clientip ""
  if { [HTTP::header exists "X-Forwarded-For"] } {
    set clientip [HTTP::header "X-Forwarded-For"]
    set clientip [IP::client_addr]
  persist uie $clientip
  log local0.info "add persist XFF=$clientip"
when HTTP_RESPONSE {
  log local0.info "$clientip"
  persist add uie $clientip
What I see in the logs is the information i logged with the Irule that seems OK , and then a TCL error , and the F5 reset the connection to the client and to the server.
Sun Apr 4 11:46:21 CEST 2021 err lbc3sd01 tmm1 [20064] 01220001 TCL error: /LAN_10G/IDP.RE7.PERSIST.ON.XFF <HTTP_RESPONSE> - bad option "10.231.227.101": must be any, virtual, service, or pool while executing "persist add uie $clientip"
Sun Apr 4 11:46:21 CEST 2021 info lbc3sd01 tmm1 [20064] Rule /LAN_10G/IDP.RE7.PERSIST.ON.XFF <HTTP_RESPONSE>: x.x.169.38, 10.231.227.101
Sun Apr 4 11:46:21 CEST 2021 info lbc3sd01 tmm1 [20064] Rule /LAN_10G/IDP.RE7.PERSIST.ON.XFF <HTTP_REQUEST>: add persist XFF=x.x.169.38, 10.231.227.101
in the logs of the client , I see also
Apr 1 21:55:22 nam02 httpd[32444]: [proxy_http:info] [pid 32444:tid 140401994258176] [client 10.231.227.101:54900] received response from server
Apr 1 21:55:22 nam02 httpd[32444]: [ssl:debug] [pid 32444:tid 140401994258176] ssl_engine_io.c(2214): [remote 10.219.4.66:8443] OpenSSL: I/O error, 5 bytes expected to read on BIO#7fb15400bad0 [mem: 7fb154067963]
Apr 1 21:55:22 nam02 httpd[32444]: [ssl:info] [pid 32444:tid 140401994258176] (104)Connection reset by peer: [remote 10.219.4.66:8443] AH01991: SSL input filter read failed.
Apr 1 21:55:22 nam02 httpd[32444]: [proxy_http:error] [pid 32444:tid 140401994258176] (104)Connection reset by peer: [client 10.231.227.101:54900] AH01102: error reading status line from remote server 10.219.4.66:8443
Apr 1 21:55:22 nam02 httpd[32444]: [proxy_http:debug] [pid 32444:tid 140401994258176] mod_proxy_http.c(1442): [client 10.231.227.101:54900] AH01105: NOT Closing connection to client although reading from backend server 10.219.4.66:8443 failed.
Apr
1 ACCEPTED SOLUTION
SanjayP
MVP
MVP
Is there a reason you are adding persistence in the http response event?
​I think since you want to create persistence from the client side information (XFF/src address) adding it in the http request event would be enough.
 if {[HTTP::header X-Forwarded-For] != ""} then {
persist uie [lindex [ split [lindex [HTTP::header values X-Forwarded-For] 0] "," ] 0]
persist uie [IP::client_addr]
6 REPLIES 6
SanjayP
MVP
MVP
Jumbo
Altostratus
Altostratus
Are you sure ? for me , You can only add persistence records to the table when the server is selected,
so in the response, you add a record to the table and in the request, you readit
SanjayP
MVP
MVP
Yes, to my knowledge. persist add uie is used if persistence needs to be created based on the server response. e.g. JSESSION ID or custom cookie created.
https://devcentral.f5.com/s/question/0D51T00006oHHj1/universal-persistence-irules-persist-uie-comman...
I would suggest if possible try in nonprod environment. or we can either wait to see if someone else has other opinion here.
Jumbo
Altostratus
Altostratus
I 'll tried to implement it as you proposed and will keep you informed about the result
Jacques
Jumbo
Altostratus
Altostratus
Hi F5rocks
I implemented it, and it seems working as expected.
thanks very much for your help
Jacques
That's nice to hear. If you select this answer as best it would close this conversation. Thanks! ​
