21-Jul-2023 10:26
dear,
I try to search on how we can configure mx record using wilde ip, is there any article describe the steps , how we can configure this
Solved! Go to Solution.
27-Jul-2023 09:17 - edited 27-Jul-2023 09:19
Hello @Amr_Ali ,
It's applicable in Bigip DNS , Follow these Steps :
Assume you have only two records or 2 ips for mail server.
Follow these steps :
I tested it and it worked , so it's your turn and let me know the updates 🙂
22-Jul-2023 10:58
I am just confused about something, To create an MX record with wild IP, i need to create a server then create vs, then create a pool and add vs to it, and then attach this pool to wild ip,
in this situation what kind of server, it will be the IP of the mail gateway that used in my environment
Hello @Amr_Ali ,
