23-Jun-2019 16:03
Hello ,
i am on F5 - 13.1.4 and am trying to setup sso for remote desktop - i have enabled sso when setting up desktop - but its still not signining on and asking for username and password - meaning - giving a prompt
logs indicate username - domain and password variables are set but still not working
Question - do i need to do a sso mapping (i thought that was not necessary)
2 - do i need to setup NTLM2 sso for this ?
thanks
23-Jun-2019 21:34
what variables are defined in rdp sso section?
if source variables are session.sso.token.last.username and session.sso.token.last.password, you need to set these variables...
sso credential mapping is a tool to do it but you can also do it with variable assign
Rdp does not use NTLM sso.
are you sure session.logon.last.domain is configured with NT domain name?
23-Jun-2019 22:20
Thanks for the reply -
i have added variable assign -
session.logon.last.username = session.logon.last.username
session.sso.token.last.password = expr { "[mcget session.logon.last.password1]" }
session.logon.last.domain = expr {"RVM"}
and i can see in th elogs as well (debug) - that
_resource_remote_desktop./MGM/S01.domain' set to 'RVM'
resource_remote_desktop./MGM/S01.password' set to '**********'
resource_remote_desktop./MGM/S01.username' set to 'TESTUSEr'
but still - get a logon prompt when i launch RDP
23-Jun-2019 22:32
Did you set a ssl profile to the vs?
if yes, don’t use APM default server ssl but serverssl.
i got issues with sso because APM did not trust rdp server CA (not listes in trusted ca defined in this ssl profile)
24-Jun-2019 00:03
hi - i am using server ssl
24-Jun-2019 00:04
24-Jun-2019 10:44
Is the variable session.logon.last.password1 encrypted?
In variable assign for password, set it as secured and use expression
expr { "[mcget -secure session.logon.last.password1]" }
24-Jun-2019 19:04
no luck
24-Jun-2019 19:04
no luck
