12-Oct-2023 05:10
hello Dears ,
we are going to do tech efresh and replace our BIG IP with new model R4600 series ,we need to confirm our understanding on SSL TLS offloading HW capacity as mentioned below , also incase there is any performance report on testing r4600 please share it's link .
30K TPS (2K SSL TPS) this mean Peak TPS while using RSA cryptography and Key size is 2048
14K TPS (ECDHE-ECDSA P-256 TPS) Peak TPS using ECC cryptography and using mentioned encryption algorithm
14K TPS (ECDHE P-256-RSA 2k TPS) Peak TPS using ECC cryptography and using mentioned encryption algorithm
20 Gbps bulk encryption total data being encrypted
12-Oct-2023 06:16
@mahmoudabdelhay I'm unsure of the question here because it looks like you pulled this information directly from the datasheet without a description on what you believe it means.
12-Oct-2023 06:42
i need only confirmation that Peak TPS 30K is tested with RSA and key size is 2048
12-Oct-2023 07:11
@mahmoudabdelhay From my understanding all specs regarding SSL are done with 2k keys and not 4k. If memory serves me right the 4k keys drops SSL by about 50% or more.
12-Oct-2023 07:33
many thanks dear for your reply , yes that is correct 4k key decrease TPS with around 20% from Peak , could you check and confirm that 30K TPS is while using RSA
