Technical Forum
SSL::payload replace - silent failure?
Darin_DeFer
Altostratus
Altostratus
We have a request to add a certificate common name (CN) string to the end of a particular type of ISO-8583 message request coming arcoss on a long-lived TCP connection.  We already extract and log elements of the message payload today...no problem.  We created a new iRule to detect the particular message type and append the trailing CN string...again no problem.
When we try to replace the payload our iRule fails silently...problem.
The syntax is pretty basic, I don't think we're fudging it up.  Anything we can do to debug WHY this particular line in our iRule is failing?
     [SSL::payload] replace 0 $data_len $new_payload;
  • We know that new_payload is good and contains the value we want.
  • We have data_len set using:  set data_len [SSL::payload length]
Have tried using "[SSL::payload]" and "SSL::payload" on the chance that the square brackets were issue.  No joy.
1 ACCEPTED SOLUTION
Can you try something like this,
SSL::payload replace 0 $data_len ""
SSL::payload replace 0 0 $new_payload
2 REPLIES 2
That was it.  I *thought* we'd tried it without the enclosing square brackets bit clearly NOT!
Many thanks!
