SSL Offloading and HTTPS:8443 to HTTP:8080
I'm running an Openstack Swift-Proxy-Server and I've got a request to do SSL offloading in BigIP LTM.
From the application, the endpoint is SSL should terminate on BigIP LTM and the endpoint from BigIP LTM to Swift-Proxy-Server will be http://proxy.sample.com:8080.
Please help check my configurations since I am getting ConnectionError: [Errno 111] Connection refused
Here is my VS config:
Destination Address: 10.0.0.128 Service Port: 8443 | Others Protocol: TCP SSL Profile (Client): ssl_certificate Address Translation: Enabled Port Translation: Enabled: Source Port: Preserve Others is set to default
Here is my Monitor config:
Name: Monitor_8080 Type: TCP Alias Address: All Address Alias Service Port: 8080 Others is set to default
Here is my POOL config:
Health Monitors: Monitor_8080 Members: 10.0.0.129:8080 and 10.0.0.130:8080 Others is set to default
