12-Aug-2020 10:11
Hello there,
We have a F5 LTM and a virtual server configured to a server in port 443, the topology is:
Computer --> F5 LTM --> switch --> server
When we try to connect to the server through https we saw the message "Connection reset" in the browser, but if we try to connect without passing the F5 the connection is successful. We don't have configured any SSL client profile or server.
This is the configuration on F5:
#Virtual Server
#________________________________________________________________________________
ltm virtual /Common/Server1 {
destination /Common/10.1.5.X:443
ip-protocol tcp
mask 255.255.255.255
pool /Common/Server1
profiles {
/Common/tcp { }
source 0.0.0.0/0
translate-address enabled
translate-port enabled
#Pools
ltm pool /Common/Server1 {
members {
/Common/10.1.7.X:443 {
address 10.1.7.X
monitor /Common/https_443
#Profiles
# -Default Profile-
ltm profile tcp tcp {
ack-on-push enabled
close-wait-timeout 5
congestion-control high-speed
deferred-accept disabled
delayed-acks enabled
ecn disabled
fin-wait-timeout 5
idle-timeout 300
keep-alive-interval 1800
limited-transmit enabled
max-retrans 8
nagle disabled
proxy-buffer-high 49152
proxy-buffer-low 32768
proxy-mss disabled
proxy-options disabled
receive-window-size 65535
reset-on-timeout enabled
selective-acks enabled
send-buffer-size 65535
slow-start enabled
syn-max-retrans 3
time-wait-recycle enabled
time-wait-timeout 2000
timestamps enabled
As you can see, we don't have any SSL client or server profile and we tried changing "translate-port" to disabled and "Source Address Translation" to auto map but none of these work.
Also we made a tcpdump and we can see the TCP Reset from 10.1.7.X (tcpdump.png) and some curl (curl.png), openssl (openssl.png and openssl2.png) and a telnet (telnet.png).
Hope you can help us to find out what's going on.
Thank you.
01-Sep-2020 09:58
Your virtual server is very simple with no profiles that should interfere.
Telnet isn't a good test for SSL connections other than stating that the port is open, use openssl or another utility to test the connection.
You have to have some sort of SNAT translation enabled because your virtual server and pool member exist on different networks. Automap should be fine assuming you have a valid self-ip configured.
The F5 is not manipulating the SSL handshake and especially not the http traffic considering it can't decrypt any of it due to SSL passthrough being configured here.
Given the very simple configuration of the virtual server this would seem to be more likely an issue with the server or device between F5 and server.
You can take a capture with F5 'noise' to see the reset cause:
tcpdump -s0 -ni 0.0:nnnp host 10.1.7.x and host source_ip
