20-Apr-2020 13:35
Hi ,
We have the requirement to enforce the mutual-auth (client cert) based on the incoming uri. The irule is written and it is able to SSL renegotiate and request the cert. The cert is added to the header and sent to the server pool.
In the HTTP_RESONSE , able to the see the 302 from the server. however the is ssl connection reset error on the browser. I need help on with the irule event and the log i can add to see the response leaving from the F5 (to the client).
when CLIENT_ACCEPTED {
set session_flag 0
set cert "string"
set ccount 0
# During SSL handshake, if there is a client cert presented, increases the ccount, and sets the cert
when CLIENTSSL_CLIENTCERT {
# Checks the client cert count.
if { [SSL::cert count] > 0 } {
#log local0. "[IP::client_addr] Setting the cert variable"
# Removes gibberish
set cert [string map -nocase { "-----BEGIN CERTIFICATE-----" "" } [X509::whole [SSL::cert 0]] ]
set cert [string map -nocase { "-----END CERTIFICATE-----" "" } $cert ]
set cert [string map -nocase { " " "" "\n" "" } $cert ]
# Increases the ccount
incr ccount
# Releases the HTTP after the negotiation
HTTP::release
# During HTTP_REQUEST, checkes cert count, HTTP query. If both conditions are met, triggers the client cert renegotiation.
if { [SSL::cert count] < 1 } {
# Checks if incomming HTTP::uri matches the DGL
if { [class match [string tolower [HTTP::uri]] contains SSO_URI_INCOMMING ]} {
#log local0. "[IP::client_addr] No certificate found. Request certificate"
# Sets client cert negotiation parameters.
SSL::authenticate always
SSL::authenticate depth 9
SSL::cert mode require
SSL::renegotiate enable
SSL::renegotiate
# Holds the HTTP flow until HTTP::release at the end of CLIENTSSL_HANDSHAKE.
HTTP::collect
# Prior to sending the request to the server, insert the cert into the HTTP header.
when HTTP_REQUEST_SEND {
# Checks number of certs negotiated. If at least one, insert the cert into client side HTTP header.
if { $ccount > 0 } {
clientside {
#log local0. "[IP::client_addr] Inserting certificate into HTTP header"
# Inserting the cert.
HTTP::header insert "CLIENT_CERT" $cert
when HTTP_RESPONSE {
#log local0. "[HTTP::status]"
21-Apr-2020 09:18
What do you have is the log (cat /var/log/ltm) ?
I suspect you are falling under this case :
https://clouddocs.f5.com/api/irules/HTTP__collect.html :
This command cannot be called after any Tcl command that sends an HTTP response (e.g. redirect, HTTP::redirect, and HTTP::respond). A run-time error will result.
01-May-2020 06:17
Hi ,
Thanks for the response , I figured the issue, the cert was verified against the CA. We had the right cert and CA file uploaded, it resolved the issue.
