Technical Forum
SPLUNK
Poseidon1974
Cirrus
Cirrus
Hi ,
to exploit the logs of the F5 LTM, APM,  I would like to use, SPLUNK, and to avoid doing TCPDUMP on an environment of  F5, do you know which keywords I could use on splunk.
Thanks,
4 REPLIES 4
Paulius
MVP
MVP
@Poseidon1974 I don't believe you can have the level of detail on a SPLUNK server that you can on a tcpdump on the F5, you will receive log messages but nothing as informative as a tcpdump.
If that was the correct answer for you, please flag it as such.
I totally agree on the answer btw, logging and tcpdump are different things. won't be possible to pull that traffic logging into Splunk.
