Split tunnel configuration with DNS Address Space
R_
We are currently setting up split tunnel, we are using DNS Address Spaces to allow the domains we are using.
If FQDN does not resolve to the IP address ranges that was defined in the IPV4 Address Spaces, will traffic for the FQDN still be routed to the tunnel?
2 REPLIES 2
PeteWhite
F5 Employee
F5 Employee
That is a really good question - the short answer is yes, I think so because the policing is done on the tunnel at the client end but maybe you can test it and let us know.
Dimalaz
Any update on this setting? Is this possible?
I have the same demand form a customer
Thanks,
