Chause1
Jul 24, 2020Cirrus
Soap persistence on session ID
Good day,
I'm trying to configure an I rule to do Session id Persistence.
The Session ID is contained in the tag of the SOAP request and will need to be used as the persistence record.
I noticed that there are some already listed on DevCentral, however these rules use a specific session ID.
In our case the user session ID will change per user
A SID (session ID) is returned only if the access is authenticated. All subsequent web services calls need to include this SID.
