Technical Forum
SNMP OIDs for i5600 and i7600
Hello All...I am looking for the SNMP OIDs, How can we figure out which OID is correct for our device. I beleive the MIB file has everything not just specific to the platform
2 REPLIES 2
whisperer
Cumulonimbus
Cumulonimbus
Have you seen the following in regards to using SNMPWALK to find the tracked OIDs? Iv usually run this in the past via terminal and then pick out what I am interested in.
https://my.f5.com/manage/s/article/K84194257
You can then access the MIBs for export via HTTPS GUInand import into your 3rd party monitoring tool. This will get you the OID and name mappings, which helps quite a bit!
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-external-monitoring-implementations-13-0-0/13.html
Will try it
