Prakin's avatar
Prakin
Icon for Cirrus rankCirrus
Dec 14, 2020
SNMP Load balancing
is it possible to load balance SNMP(UDP) traffic to pool members (as SNMP collector servers). i am assume its possible, i just worried about the load on the LTM.
Br,
Prakin
  • Hello Prakin.
    Of course you can.
    https://support.f5.com/csp/article/K7535
    https://support.f5.com/csp/article/K3605
    Regarding the capacity of the device, you can check how many L4 connection the device can assume.
    https://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
    Regards,
    Dario.
