Seven11
Dec 29, 2017SNMP for CPU, Memory and Disk Usage
Ive got 3 different Hardware Setups (Bigip i5600, i2600 and i7800).
1. What are the correct OIDs if i want to check the Hardware:
- CPU Usage (not every core / just one single result)
- Memory Usage (for the whole hardware system if possible)
- Disk Usage (for the whole hardware system if possible)
2. What are the correct OIDs if i want to check the VCMP Guests on the i7800:
- CPU Usage
- Memory Usage
- Disk Usage
There are a lot on the MIB Files and Results but which are the OIDs you want use in this case?
- jaikumar_f5
Noctilucent
You can go over these 3 files and find it,
/etc/alertd/bigip_dmon_error_maps.h /etc/alertd/alert.conf /etc/httpd/run/bigip_error_maps.datReference article,
- Srini_87152
hi,
Please refer https://support.f5.com/csp/article/K6854
you can all details from MIB file..which can download from F5 it self.
Thx Srini
