SNAT CONFiuration
I really confuse with SNAT regarding config. i know it change Source address. but config little confuse somet time
theee 2 way i saw config
First--
I select in pool SNAT and in virtual server "NONE"
here is connection entry.
show sys connection cs-server-addr x.x.x.x with this I see only three column
CLEINT source address Virtual server ip member of pool
WITH THIS FIRST CONFIG >>>> SNAT WORKS ?
Second --
I select in POOL SNAT and in virtual server i select "SNAT AUTOMAP" with this i see Four column
CLEINT source address Virtual server ip SNAT IP member of pool
1. when should i configure first configuration and when should i configure second config .?
2. IF in pool i don't select SNAT and in virtual server i select "SNAT AUTOMAP" will SNAT WORKS ?
Thanks & Regards
A.N
