30-May-2019 11:45
ALCON need an assist if you can. I have a customer who want a TCPDUMP using a specific filter.
(ip.src == 192.102.67.73)
&& (tcp.srcport == 443)
&& (tcp.flags == 0x018)
&& (tls.record.content_type == 22)
&& (tls.handshake.type == 2)
&& !(tls.handshake.ciphersuite in {0xc02b 0xc023 0xc02c 0xc024 0xc02f 0xc030 0x1301 0x1302})
30-May-2019 14:27
There exists a great doc to deal with that
REF - https://support.f5.com/csp/article/K2289
KR,
Dario.
30-May-2019 15:42
WIRESHARK <-> TCPDUMP
(ip.src == 192.102.67.73) <-> (src host 192.102.67.73)
(tcp.srcport == 443 <-> (src port 443)
(tcp.flags == 0x018) <-> (tcp[13] == 24)
(ssl.record.content_type == 22) <-> (tcp[((tcp[12] & 0xf0) >> 2)] = 0x16)
(ssl.handshake.type == 2) <-> (tcp[((tcp[12] & 0xf0) >> 2)+5] = 0x02)
You cannot create the last line in tcpdump. Take into account tcpdump uses a deterministic matching. To do the last, you should use post-processing (scripting).
I would appreciate if you rate my answer.
KR,
Dario.
30-May-2019 14:37
So what was the question? Or you simply want that translated into a tcpdump filter
I'd recommend you look at 'man tcpdump' myself. Which would (probably) lead you to 'man pap-filter'. Or google for 'tcpdump filter'. However as a hint
&& (Logical And) becomes 'and' (Or you can leave it as && if you really want but replacing and, or with &&, || will require single quotes around the filter).
ip.src == 192.102.67.73 becomes 'src 192.102.67.73'
tcp.srcport == 443 becomes 'src port 443'
tcp.flags = 0x018 becomes 'tcp[13] = 26'
The others become a bit more complex... You'd really have to know the offsets into the packet to check them (I don't know them off hand sorry). However this may help
http://blog.fourthbit.com/2014/12/23/traffic-analysis-of-an-ssl-slash-tls-session
There's lots of useful pages available on the internet for tcpdump filters. e.g
https://danielmiessler.com/study/tcpdump/
30-May-2019 15:02
Thanks team ; I was able to figure out the first there also . Its the tls part of the configuration I am having issue with.
I
