Setting default route using VLANs
We have a setup using more than one VLAN for the VIPs. This is functioning, but I would like to add default routes for each VLAN. Am I correct to create a route for each VLAN using the next settings ? Then I have the problem I can not add the gateway for that VLAN.
Description :
Destination : 0.0.0.0
Netmask : 0.0.0.0
Resource : Use VLAN /Tunnel
VLAN / Tunnel : vlanA
MTU : 0
Main question are :
- Do I need the default route for each VLAN or can I count on the "Auto Last Hop" function ?
- If yes, how to create the default route for each VLAN using the gateway in that VLAN ?
Hello Willy,
You're welcome. If my answer was helpful, please don't forget to tag it as 'the best' to help other people to find it.
Regards,
Dario.
- Dario_Garrido
Noctilucent
Hello Willy.
Only configure one single default route for generic traffic and let "Auto Last Hop" feature to work for the rest virtuals located in the rest of VLANs.
REF - https://support.f5.com/csp/article/K13876
Regards,
Dario.
- Willy
Hello Dario,
Thank you for confirming the auto last host feature and the extra info.
Kind Regards,
Willy
- Dario_Garrido
Noctilucent
Hello Willy,
Regards,
Dario.
- Willy
Hello Dario,
I did select the best just a moment ago.
