Technical Forum
Set a variable from a Data group
Mario_Franco
Altostratus
Altostratus
Hi everyone,
I have an irule with a static variable "set example 1" which is used when we need to point to a specific virtual server, and we change it to "Set example 0" when we want to move the traffic to another virtual server, the thing is now we have many irules and when we want to move the traffic we need go one by one and change the variable, I am thinking of setting the variable with a data group where we just need to go there and change the value in the datagroup "1" or "0", is it possible? or there are any other option?
1 REPLY 1
You probably have figured it out by now but just in case, here's an example.
Data group list:
ltm data-group internal /Common/select_server {
    records {
	server {
            data a
    type string
And the rule:
  # Below is the droid... I mean line you're looking for
  set selected_server [class lookup "server" select_server]
  HTTP::respond 200 content $selected_server
 Good luck!
Kind regards,
Patrik
