04-May-2017 03:31
"In addition, for portal access, you can customize the timing for the warning message to appear for the user prior to session timeout by using the Session Timeout Guard Time setting in the webtop customization settings."
Can you tell me how to find where that Session Timeout Guard option is located ?.
Thank-you
23-Nov-2020 10:44
not very useful for the op i expect, but if someone is looking and find this question:
via Customization > General and then Webtops > name > Branding - Web Application Session Time you can make a change to the Guard time
