01-Feb-2021 01:51
Session are getting dropped post upgrade 15.x.x and sessions are not seen in traffic log to analyze further.
Previously was working fine. Every config is iRule based like iRule is attached to VS.
what could be possible workaround or solution, please help.
F5 LTM is used as webproxy. Also help how to log dropped traffic on F5.
01-Feb-2021 10:12
I suggest you open a case with support since you are experiencing degraded performance. Some thoughts to consider as you work through the issue:
