Technical Forum
Custom Alert Banner
Security Policy not syncing between devices
buzzkiller
Altostratus
Altostratus
Greetings,
A few days ago, I had to perform a security update and observed a discrepancy in the synchronization of security policies between the two high-availability (HA) devices. To illustrate, a security policy that appeared transparent on the active device was found to be blocking when the standby device took over. The disparity extended beyond just the enforcement mode; even the rules differed, resulting in the unintended blocking of legitimate traffic.
I mention that "Application Security Synchronization" is enable for the device group.
Software version is: 15.1.10.2
1 ACCEPTED SOLUTION
M_Saeed
Cirrus
Cirrus
@buzzkilleryou could follow this up as hereunder and let me know if it is fixed or not.
1- make sure to create a new device group "sync-only",  you could create it sync automatically or manually
2- then assign it under Security ›› Options : Application Security : Synchronization : Application Security Synchronization
3-and repeat applying sync on it.
4- After making sure syncing with that approach, try again to set WAF sync back to "datasync-global-dg" not your created sync-only group.
-> it would be resolved
3 REPLIES 3
M_Saeed
Cirrus
Cirrus
Thank you! It worked 😁
There are a lot of bugs about this Bug Tracker | MyF5 . I think that you have to switch between groups and test the @M_Saeed solution.
