Technical Forum
Security headers
THE_BLUE
what are the security headers that sould be added in all websites? is there any irule to add all needed headers?
2 ACCEPTED SOLUTIONS
Paulius
MVP
MVP
@THE_BLUE The following article is something I found with best practices for security headers and based on what I can tell you can create an iRule or use a virtual server setting accomodate them all. I don't know of a standard iRule for each use case but I would imagine search DevCentral (this forum) for the respective header will provide you several articles where someone has solved this issue.
https://www.globaldots.com/resources/blog/the-8-http-security-headers-best-practices/
The following is an example of a search that can be performed on a topic in the URL provided above.
https://community.f5.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=C...
Hi @THE_BLUE ,
Please have a look in the following Articles :
https://my.f5.com/manage/s/article/K57207881
https://community.f5.com/t5/codeshare/adding-security-http-headers-with-an-irule-for-hsts-xss/ta-p/2...
In addetion to using Cookies and http only features.
_______________________
Regards
Mohamed Kansoh
2 REPLIES 2
Paulius
MVP
MVP
Hi @THE_BLUE ,
Regards
Mohamed Kansoh
