David_Dalgaard_'s avatar
David_Dalgaard_
Jul 24, 2013
Script to check for certificate expiration
Hi guys
Most of you have probably been in the situation where a certificate suddenly expired without anyone noticing (or at least no one took proper action). I was in that situation a couple of weeks ago. I asked Lord Google if someone had a good method of detecting certificate expiration automatically. I didn't really find anything relevant, except for a couple of SOLs from F5 regarding the checkcert utility. So I sat down and did some scripting myself. I'm pretty satisfied with the result, however, this is my first real bash script so you can probably find something that could be optimized or done in a better way.
So first of all the scripts checks if the device is the active box. If it is not, the script does nothing, but if is, the script creates a list of all expiring certificates and places them in expiringcerts.txt. This file is then checked and each line is reported separately to our servicedesk (which in return creates a case and escalates it directly to network operations). When a certificate has been reported it is put in the flaggedcerts.txt. This file ensures that a certificate is not reported multiple times, unless it is less than a week from expiring. In this case a new mail is send each time the script is ran (in our case, it is put in /etc/crontab and configured to run every day at 12 pm/noon).
If a certificate is deleted, expired or renewed it is no longer put in the expiringcerts.txt file and is therefore also removed from the flaggedcerts.txt file.
In the end a status mail is sent to me each day to ensure that the check ran as it should. This is just me that like to be absolutely sure that the script does its job.
___________________________
!/bin/bash
Author: dadalife
Check if unit is active and if it is the script should continue:
ACTIVE=$(tmsh show cm failover-status | grep ACTIVE | wc -l)
if (($ACTIVE == 1)); then
echo -e "Unit is active. Proceeding...\n"
SCRIPTPATH='/root/'
MAIL='[email protected]'
MAILCC='[email protected]'
NUMREPORTED=0
NUMFLAGGED=0
NUMCRITICAL=0
Create a list of all expiring certificates:
tmsh run sys crypto check-cert | grep 'will expired' | awk -F 'in file' '{print $2}' | awk -F ' GMT' '{print $1}' > "$SCRIPTPATH"expiringcerts.txt
echo "A list of all expiring certificates has been created!"
Send an email for each certificate if it has not already been sent:
echo -e "\nChecking for expiring certificates..."
> "$SCRIPTPATH"tempflagged.txt
while read line; do
BODY="\n\nPlease create this case as an incident (Priority 3) under the customer CNM and escalate directly to OPNOM.\n\nThis is an auto-generated e-mail from the BIG-IP."
CERT=$(echo $line | awk -F ' ' '{print $1}')
CERTEXPIRE=$(echo $line | awk -F 'expired on ' '{print $2}')
FLAGGED=$(cat "$SCRIPTPATH"flaggedcerts.txt | grep $CERT | wc -l)
if (( $FLAGGED == 0)); then
echo $CERT >> "$SCRIPTPATH"tempflagged.txt
echo -e "$CERT expires on $CERTEXPIRE GMT.$BODY" | mail -s "$CERT expires on $CERTEXPIRE GMT" $MAIL -c $MAILCC
echo "--> $CERT reported to servicedesk."
NUMREPORTED=$[$NUMREPORTED +1]
else
echo "--> $CERT has already been flagged"
NUMFLAGGED=$[$NUMFLAGGED +1]
fi
done < "$SCRIPTPATH"expiringcerts.txt
cp "$SCRIPTPATH"tempflagged.txt "$SCRIPTPATH"flaggedcerts.txt
echo -e "Check for expiring certificates done!"
Check if a certificate is less than a week from expiring:
CURRENTTIMEEPOCH=$(date +%s)
echo -e "\nChecking for almost expired certificates..."
while read line; do
CERTEXPIREEPOCH=$(date --date="$CERTEXPIRE" +%s)
CERTEXPIREDIFF=$(expr $CERTEXPIREEPOCH - $CURRENTTIMEEPOCH)
if (($CERTEXPIREDIFF < 604800)); then
BODY="\n\nPlease create this case as an incident (Priority 1) under the customer CNM and escalate directly to OPNOM.\n\nThis is an auto-generated e-mail from the BIG-IP."
echo -e "$CERT expires on $CERTEXPIRE GMT.$BODY" | mail -s "WARNING: $CERT EXPIRES IN LESS THAN A WEEK!!" $MAIL -c $MAILCC
echo "--> WARNING: $CERT EXPIRES IN LESS THAN A WEEK!!"
NUMCRITICAL=$[$NUMCRITICAL +1]
fi
echo "Check for almost expired certificates done!"
echo -e "\nCertification check done!"
Send a status email:
echo -e "Hi David\n\nYour script did its job!!\n\nNumber of newly reported certificates: '$NUMREPORTED'\nNumber of already flagged certificates: '$NUMFLAGGED'\nNumber of critical certificates: '$NUMCRITICAL'\n\nYours Sincerely\nThe BIG-IP" | mail -s "Everthing went well!" $MAILCC
else
echo "Unit is standby. No action taken!"
fi
___________________
Feel free to comment on anything! :)
Thanks,
David
