sccm 2012 internet based client management & LTM...
I have a question regarding the configuration of client and server authentication on the BIG-IP LTM from sccm 2012 clients that are internet based. The ports SCCM 2012 uses for client authentication are on port: 443 and there is an external URL that points to the internal SCCM server. The client has a PKI certificate that uses workstation authentication and the server has IIS with the PKI web server certificate that has the FQDNs of the external and internal server names. How would you go about setting up rules for both the server and workstation that all use the port 443? If anyone has any information on this at all I would greatly appreciate the help. If you need anymore information please let me know and I will provide it.
Thank you for your time.
