24-Aug-2020 05:03
so i was just going to implement adding the samesite attribute to our APM cookies (MRHSession etc) when i failed miserably, because it seems the change, that you cannot read any HTTP headers after having an irule respond command also applies to APM responses.....
when CLIENT_ACCEPTED {
ACCESS::restrict_irule_events disable
when HTTP_REQUEST priority 50 {
set userAgent [HTTP::header User-Agent]
when HTTP_RESPONSE_RELEASE priority 50 {
if {![info exists userAgent]} {
return
if {![call /Common/RuleUtil::check_samesite_config $userAgent]} {
unset -nocomplain userAgent
return
set named_cookies [list {MRHSession} {LastMRH_Session}]
foreach cookie $named_cookies {
if { [HTTP::cookie exists $cookie] } {
HTTP::cookie attribute $cookie remove {SameSite}
HTTP::cookie attribute $cookie insert {SameSite} "None"
HTTP::cookie secure $cookie enable
unset -nocomplain $named_cookies
This results in:
Aug 24 11:52:49 redacted err tmm[20803]: 01220001:3: TCL error: /Common/SET_SAMESITE_APM_COOKIES <HTTP_RESPONSE_RELEASE> - Can't call after responding - ERR_NOT_SUPPORTED (line 23) invoked from within "HTTP::cookie exists $cookie" ("foreach" body line 3) invoked from within "foreach cookie $named_cookies { if { [HTTP::cookie exists $cookie] } { log loca..."
And after a quick check i noticed that HTTP::has_responded does indeed return 1 for APM events.
So, how are we supposed to support SameSite attributes on APM cookies in v15?
Thanks!
Rene
