Technical Forum
Running bigip to terraform resources
niclan
Altostratus
Altostratus
Posting here in the hopes someone finds this useful.  This is not a product, it's a small open source tool that I've made to help manage our BigIPs.
TL;DR: Running BigIP to Terraform resources: https://github.com/schibsted/bigip-to-terraform
We recently started speaking about managing our BigIP in a more DevOpsy way at work.  We have been using the web GUI most of the time and recently it has become more and more tricky to do transformations on the config text file to do large scale changes.
We use terraform for AWS and some other things and I've not used it much myself so I thought I'd give terraform for BigIP a go.
After looking at the docs and comparing with our running config and speaking to some different colleagues I found I wanted to see a terraform representation of our running config to see how new resources could be configured.
So I wrote a script to dump our running config to terraform resources. It uses the python API to extract VIPs, pools and attendant nodes, writes a skeleton resource file and then "terraform import"s each resource.  After that it uses "terraform show" with some light processing to generate a complete and valid terraform .tf file for all the resources found.
There is one specific bug in the BigIP plugin to terraform (see the "issues" on github) that stops me from getting a complete automatic extract in our environment.  And also for our full configuration (once I've removed the VIP resources that causes problems) "terraform plan" takes between 15 and 25 minutes. So I made a option to extract just VIPs matching a string or RE pattern, as well as their attendant pools and nodes.  I've been able to "terraform apply" these back to a BigIP.
The README file is quite complete, basically do `./runner` to get it all or `./runner -v 'pattern'` for a substring match in the VIP name, full path or IP number.
This is not a migration tool since it does not extract or handle iRules, policies and such at all, they have to exist in the target environment already.
3 REPLIES 3
buulam
Community Manager
Community Manager
This is really cool @niclan ! This post might belong in the CodeShare. Will check with the other mods
@buulam / YouTube.com/DevCentral
LiefZimmerman
Community Manager
Community Manager
Yep - perfect candidate for CodeShare. I will nominate it to be moved.
niclan
Altostratus
Altostratus
I should mention that this script keeps making the terraform bigip plugin crash. Two issues I reported were fixed in 1.16.2 but another one cropped up.  ... I've opened a new support case.
