Willy's avatar
Willy
Aug 12, 2019
Running Avanti CSA through LTM/ASM
We are using the F5 release 12.1.3.7 and are trying to run the Avanti Cloud Services Appliance through a virtual server to have ASM checking.
Does some have experience with this ?
Is the Avanti application build to run through an F5, since it has lot's of firewall things itself.
Up to now the next tests have been done.
Basic setup => just running through as a tcp service on port 443 is ok
SSL setup => http profile, SSL client and standard serverssl gets no answer since the Avanti application blocks the request as it detects the F5 as a man-in-the-middle attack.
SSL setup with proxy SSL and modified serverssl profile results in the message SSL_ERROR_NO_CYPHER_OVERLAP.
